PC No Longer Booting!
30 May 2003
UK
Ok so I suspected this day may come, pc has been taking 2 or 3 attempts are start up to turn on, however this morning it is refusing to do it at all.
What happens is that when I press the power button everything spins up but there is either a) nothing happening or b) windows is loading however as nothing is happening on the monitor I wouldn't know. The GPU fan spins at full speed unlike normally when it drops to idle after booting.
The PC is a fairly old E6300 with P5N-E Mobo which has no vga out on the mobo so i cant bypass the GFX card.
So either it's the PSU or the GFX in my numpty opinon? Now I am tempted to buy a 8400GS gfx card and swap it for the 8800GTS which is currently in there (dont play any games now so performance isn't really needed).
Anyone else ever had the same problem and want to save me £25 buying a new GFX if it's not likely to be that?
Cheers,
Neil.
I took the CMOS battery out this morning as I suspected that it might be causing the dodgy startups, put a new one in and then it didn't boot at all, put the old battery back and it still isn't.
It's not the monitor already tried it on another pc. :(
No display at all, all the fans spin up as normal, however the GFX fan normally spins up full speed then drops, it's not dropping anymore and just carrys on at full wack! Nothing unplugged, same stuff as there has been for the last 5 years.. :(
Try cleaning out the dust???
does it even make a beep? or do you not have a speaker on mobo?
u can buy one cheap
also, I unplugged myne from the back leave it for 20 mins then it worked again
No beeps at all, it's just like a normal boot apart from it doesn't even get to POST.
No other PSU however I think theres another PCIe slot I can try, if it still doesn't work ill have to buy a new GFX card I guess. :(
i think the diodes have blown on the gfx card. Try another gfx card in the rig & try that one in another PC.
I have exactly the same problem, at my wits end so changing mb and psu tomorrow. I replaced my ram and hdd, as last one badly corrupted. Hopefully that'll soort it - I needed to upgrade but now hoping its not gfx card.
Changed the GFX card and still nothing, going to hazard a guess and say its the MOBO that has gone, although I guess it could be the PSU. Would a slowly failing pc seem to indicate the Mobo or PSU?
