- 4 Apr 2012
- England
Hello,
Around 8 months ago I built a PC for my dad, and it no longer boots properly.
Specs:
Intel 330 Series 60GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail
MSI H77MA-G43 Intel H77 (Socket 1155) DDR3 Micro-ATX Motherboard
Intel Pentium G840 2.80GHz (Sandybridge) Socket LGA1155 Processor - Retail
Corsair Builder Series CX 430W V2 '80 Plus Bronze' Power Supply (CP-9020046)
Zalman T1 Mini Tower Case - Black
Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100)
GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD38GB1600C11DC) £29.99
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
It was all fine, and the problem started occurring around a month or so ago. Basically, when I/my dad would switch the computer on it would say on the monitor "going to power saving mode", as if the monitor wasn't detecting the computer. However, the PC was switched on and all fans etc were running. Sometimes it would take anywhere between 2-30 restarts to get it working and to the desktop. This did not happen all the time though, only around 75% of the time but it was quite infuriating especially for my dad. So, that was the first problem.
I tried different things (such as different monitor, mains plug socket, display cable etc). None of these worked, then I decided to take out the CMOS battery. So, I had taken it out and put it back in. Now, it won't even start properly. I can see it trying to start up (the CPU fan will spin once, stop, then again before turning off for about 3 seconds and starting up again, where it does the same thing).
Right, so now I'm stumped. It's gone from bad to possibly broken. So after this I took everything out of the case, and right now I have only the motherboard with the RAM and CPU in, with the motherboard and CPU power plugged in. Next, I took out the CMOS battery again, and shorted the reset CMOS pins before putting the battery back in. Nope. Still the same thing. Then, one time it worked and managed to stay on. Hooray! Unfortunately, I turned it off, tried again and it went back to the same rebooting loop.
As for now, I have no idea what to try next!
What I have tried:
- Taking out and putting back in the CMOS battery
- Shorting the CMOS pins
- 1 stick of RAM, and in different slots
- Removing all SATA connections
- Removing all USB connections such as keyboards
At the start when it would take several attempts to get it to load (but the computer definitely had power) I thought it would either be the PSU, the display drivers are broken or the SSD containing the OS was faulty.
However, now I'm starting to think that either the battery is knackered, or the PSU is failing.
What should I try next?
Thanks in advance for any help!!
Specs:
What I have tried:
had same problem as with all the hardware in
