k, put together all the components (see sig). Powered up, BIOS came up and i foolishly changed the RAM speed to ddr667 (which it should be.) from what the default was. i put the XP disc in, set boot priority #1 to CD Drive...and the thing rebooted..great right? No..
Nothing happened after that. So i removed cmos battery, replaced, tried again. i press the power button, everything spins (cpu fan, 2 case fans, leds come on) then goes off within 3 secs. so they all startup then stop and the pc turns itself off...any ideas wtf this is? please guys, this is so so annoying. i cant get into bios or anything, the pc just has a surge of power then nothing,..cheers!
so i've gotten a bit further, but my intial problem was with XP CD copying files from the CD to HDD, but im using a different xp cd now..so hopefully that problem wont arise again...TAKE YOUR RAM BACK OCUK!
