Hi,
When I turn on my main PC all seems normal for a few seconds, then it seems to turn off / power cuts out, then few seconds later it turns back on and carries on booting up. However I can't get the monitor to display anything, it says "Entering power saving mode" then just goes black.
I've tried with another monitor had the same problem. I've also fiddled with all the power cables and connectors reconncting them etc, and got rid of some dust inside the PC.
The PC was working perfectly fine last night and I didn't change anything.
What can I do? What could be causing this?
Any help appreciated. Thanks.
edit: specs are: Q6600, 4gb, GTX260, Vista 64
