PC not booting
25 Jul 2015
Yesterday I took my motherboard out to fit a new cooler and tested it outside of the case and it worked fine with a PC game. Installed new graphics card and I was using anti static strap throughout. It had all the components on but oitside the case. I then put it in my new itx case (Thermaltake Core V1) and when I pressed the power button, it didn't switch on, there is no post.
Its an Asus Maximus VI Impact board so I pressed the start button on the board (which is illuminated) to power it, still didn't boot. Did a BIOS flash, but didn't boot. Took of all the cables but still not booting.
Please help
Things to check,
No stray standoffs causing a short on the back of the board.
CPU cooler not to tight causing PCB to bend.
If you are using a GFX card take it out and use the boards display outs.
Check the 8pin ATX.
Things to check,
Check the 8pin ATX.
Can you explain more about the standoffs please?
When I tested it outside the case, I had to reseat the cpu because it caused post error. Then it worked fine so I never touched the cooler after that.
Well I tried powering without the GFX card but still doesnt boot.
The standoffs are the little metal things the board will sit on wherever there is a hole on the PCB to fit and attach a screw to secure the board to the case.
Not all boards have holes where a case may have standoffs pre-fitted, if so then you could have a dead short to ground and this standoff (where there isnt a fixing hole on the board) needs to be unscrewed and discarded.
This is how my standoffs look like.
I wouldn't worry to much about static being a a contributing factor to your problem.
I have never used a anti-static strap, and have never had a problem in 15 years
of building PC's
But, I have had something very similar to this before....
Try removing the 8 pin cpu connector, and reconnect it firmly.
Also, remove the cable from back of psu and mains socket at the wall, and reconnect.
