- 21 May 2021
- Scotland
Hi guys, hope this is the right place to ask.
I'm very bad with a lot of technical/hardware stuff so please bear with me.
Basically what the title says, I've had this issue since i bought the PC (pre-built).
The PC fan turns on and the monitor says its receiving signal but will just sit on a black screen indefinetly.
Monitor wont go into standby, acting as if its receiving the picture.
Does anyone have any idea what could be causing this? Could this be anything on my end that doesn't flag up in repairs/tests?
My PC is under warranty, but this will be the 3rd time sending the PC back for repairs for the exact same issue. I'm just getting a bit worn out of having to constatly reboot the PC and pack it every other month.
I'm even wondering if this isue is so trivial and not even worth having to send for repairs since it can be fixed simply turning the computer on and off again. I'm just worried that it could be a noticably bad hardware problem that would get worse over time.
Specs if needed:
Team Group Vulcan Z T-Force 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey
Samsung 500GB 860 EVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-76E500B/EU)
TeamGroup 1TB Vulcan G SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
*Build Stock* Phanteks Eclipse P400 Air Midi Tower DRGB Case - Black
*Build Stock* Gigabyte GeForce RTX 3070 Gaming OC 8GB GDDR6 Graphics Card
*Build Promo* Intel Core i7-10700KF 3.8GHz (5.1GHz Boost) Comet Lake Processor - Retail
ASUS PCE-AC56 Dual-Band Wireless AC1300 PCI-E Adapter
Edit:
I know the first time sent back, they replaced the PSU with a different model.
Not 100% certain what the notes on the second on meant, but can post them if anyone thinks it would be relevant?
Specs if needed:
Edit:
