Firstly, I'm not even sure if this is right section to post this in and if it isn't then I apologise.
I built a new system in september and up until now everything was going fine. When I was in the middle of watching a video of youtube earlier, all of a sudden I got a blue screen which I didn't completely see but I think it may have been irql_not_less_or_equal. So I try and turn it on again but it doesn't load and I assumed it may have just overheated since it's been so warm here lately.
After a while I turn it back on and it loads, I checked the hardware monitor in the BIOS for temps and saw the CPU was only at 47 and assumed it must be fine now. I go back on youtube to continue watching the video and it starts to get some slowdown and then bluescreens again, but this time with
bugcode_usb_driver.
That was the last time I was able to even get past POST. Now when I run the machine, the monitor doesn't even get a signal and the red DRAM led stays lit. If you try turning the pc on after it being switched off at the mains, it turns on, turns itself off and then instantly back on again. I've tried running the machine with nothing but the monitor connected and also have tested all of my ram individually.
Specs are:
Intel Core i7 950 3.06GHz (Bloomfield) (Socket LGA1366) - Retail
MSI GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card
Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard
Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz Low Latency Triple Channel
Corsair Force 40GB F40 2.5" SATA-ll Solid State Drive
Corsair TX 650W ATX SLi Compliant Power Supply
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM
bugcode_usb_driver.
Specs are:
