pc not seeing all cores
deadite66 said:
i remember another thread on the forum were OC sent out the wrong CPU to someone, a duel instead of a quad core.
yep thats me. i have done another post, as this time it is the right cpu and windows vista aint seeing the 4 cores
dannywaugh1 said:
also i have 2 hdd and windows vista only pics up 1 hdd but if u go into device manager theres 2? but i can use it.
Is the unseen HD formatted? You might have to do this if it isn't: Admin tools->Computer Management->Storage->Disk management (this is on XP, don't know about Vista)
ok i have sorted the problems heres what i did.
go to System Properties, then go to Device Manager, and find the APCI Proccesser or whatever its called on your computer, uninstall the device then it will ask you to restart your computer click ok then go into the bios to advanced chipset features then to cpu config, in there there is an option to enable the cpu cores looks like this cpu core 0
cpu core 1
cpu core 2
cpu core 3
only 2 of them will be enabled, enable the other 2, save changes and restart, when windows loads up it will install the drivers again to use all cores.
