Hello,
I have been using my new pc for 6 months or so with no issues and then tonight the pc switched off and wouldn't switch back on.
After some investigation the Cosair ICUE will display the warning sign when my GPU (GTX 1070) is plugged in and with the battery (1000w) on but will not start, but there's power to the motherboard (lights on). If I disonnect the power PCIe cables from the GPU but leave it connected to the motherboard the pc will start and the lights from the GPU come on. I have reset the CMOS, differen't PCIe cables, uninstalled ICUE, rebuilt the pc, nothing has worked.
I did a search and nothing came up specific to this situation.
Any help would be appreciated.
Thanks.
Thanks.
