PC not switching on...
14 Oct 2007
Worcestershire
Hey guys,
Having a issue with my PC. It will not switch on after being off for a couple of hours of more. It won't switch on with the case power button or the motherboard power button. The only way is to flick the rocker switch on the power supply off and on repeatedly for around 5-7 times. The PC then bursts into life on its own.
I am thinking maybe its a PSU issue? Any ideas? Thanks
sounds a little weird, how about trying another powercable and if you using an extension change that around
think its worth a check
Does sound like the PSU , however for good measure i would reseat the 24 pin mboard cable, 4 pin cpu and the pwr sw 2 pin connector and r/sw 2 pn connector that goes into the jfp1 section of the mboard.
