PC not turning on.
3 Feb 2011
I received my Cooler Master Storm Enforcer case today and proceeded to move everything from my previous case to it and now it won't turn on.
I've checked everything, motherboard/CPU pin plugged in, MB standoff in place, power/hd/led pin connected and everything else and nothing happens when I press the power button (tried reset button too, didn't help)
What could have happened in the process? I can't seem to figure it out. ):
Power switch on the back of your power supply? :p
That was the first thing I checked. ):
Do you get a light on the board when its plugged into the mains?
Also, check that the power button cable from the case doesn't have to be reversed. I know that sometimes I get the + and - the wrong way around and it stops the computer from turning on at all.
