pc not working
22 Nov 2007
Hi guys, last night i clicked on Sleep mode (by mistake) as usual i have to turn the pc off manually by holding down the power button (using vista 64), when i went to turn it back on again it doesn't work. It boots up and then the hard drive light won't be on after initially being so. Is the HD broken?:eek:
unplug all your peripherals apart from keyboard/mouse. hold down the power button for 30 seconds.
and try again
does it post at all?
if you really want to test out the hardware get a copy of windows PE bootable from someone and you can check on the installation and hardware
Im not to sure i should be doing the above incase i break anything. I think its the hard drive , i cant hear it at all and the activity light is never on. Forgot to mention we had two power cuts last night, but it was working after these until i tried to restart it.
