PC occasionally freezing
10 Apr 2015
Hungerford, UK, Earth
my gaming PC occasionally completely freezes. and i have to power off. maybe once or twice a week, i can be gaming or pc can be idle. i recently upgraded motherboard and RAM and re installed windows.. so the only thing carried over is GPU ,RAM, SSD, PSU. and it did it on the previous PC
any easy way to diagnose.. i have spare RAM, that i could pop in for a week
Was it a Mobo and CPU upgrade? What did you upgrade to?
Is it running completely stock? Or do you have xmp/expo enabled?
Is there anything in event viewer?
Anything in event viewer at the time of the crashes?
Just to double check, you state you replaced the motherboard and ram (Or did you mean mobo and cpu where upgraded) and then later on you say that the ram was carried over. If you got new ram and you still have the fault its not going to be that
you are correct, typo. i upgraded the motherboard and CPU, used existing ram
Can you list the hardware you where using and then what you upgraded too?
What are you using for storage? NVME drive or SSD?
gigabyte z390 i7 8700k to MSI z490 i9 11900f
OS installed on 2Tb crucial M.2.. downloaded their software and drive checks out ok
I do have spare 32gb RAM i can pinch from another pc
mine does the same, if it freezes, I can still click on things like a link in a browser, but it won't let me type in a type box, when it does this then is going to crash and restart, I know, this is so random, and ~I think that I have auto restart on, so it automaticallyrestarts the pc if there is ever an error, which it never tells me what it is, even in event viewerthis is with a completely new PC with only my old win10 cloned over
so count your lucky stars that you only freeze, because restarting is so super annoying esp when in the middle of a game of chess!
Would look at the PSU if it did it on your old pc.
Did you do a fresh install if windows?
yes fresh install of windows. and actually now i think about it new m.2 as well.
I can try the PSU, current one is a Phanteks Revolt X 1kw , which is a could one so im doubting that as well :/
mine does the same, if it freezes, I can still click on things like a link in a browser, but it won't let me type in a type box, when it does this then is going to crash and restart, I know, this is so random, and ~I think that I have auto restart on, so it automaticallyrestarts the pc if there is ever an error, which it never tells me what it is, even in event viewerthis is with a completely new PC with only my old win10 cloned overfreez
freeze as in , PC locks, need to reboot by holding power button down
At least you can rule in or out.
Would also disconnect any other drives if applicable.
so PC just crashed again and bluescreened. Then it wouldnt come back on.. sometimes there was a post bios then it locked, and then it woulddnt come on until just the a blank monitor. powered off at mains and back on still nothing, fans came on etc but no post boot.
ive whipped the side and as i have extension cables was easy to plug in another PSU. turned and a booted straight into windows. So i will leave this in for a bit and see if i get any crashes...
Phanteks PSU has a 12years warranty so i should be good on that front, althought i dont know how i prove if it is that. but i know phantesk has good customer services
Only way to tell is to leave the swapped out PSU in and if the issue goes away and nothing else has changed apart from the PSU you know its that
well its now crashed with EVGA PSU :(
swapped out RAM (although old RAM passes mem test)
then final one will be GPU
