- 6 Jan 2013
Is it worth buying a pc now when next gen consoels are coming out next christmas. Will an i5, gtx 660 and 4gb of ram be better than next gen consoles ?
All there is are rumours about the next gen console specs though, is there not?
The new xbox is likely to roughly match top-end systems for graphics performance. Or at least, based on the xbox 360 it will: the 360 launched with 512MB graphics ram, 500MHz graphics - roughly equivalent to the 7800GTX which was about the fastest GPU commonly used.
In terms of CPU the xbox was roughly equivalent to mainstream CPUs, too - 3.2GHz tri-core powerpc, at a time when the 3.4GHz Pentium 4 was popular (the P4 being faster clock-for-clock, before multi-core became popular)
If the new xbox follows a similar theme, it will be about as fast as an i5 with something like a 7950, for about 1/2 to 1/3 of the price - but it will still be slower (or just not able to be used) for anything other than gaming/TV, and you have no upgrade path.
The Running Man - price isn't important in this case, as Microsoft doesn't just buy PC-grade graphics cards and whack them in an xbox. The xbox 360 at launch cost approximately the same as the 7800GTX (£250-300) which it matched in performance.
ok thanks, hopefully it dosent kill pc gaming if its that spec with half the price :O
Still playing FPS on consoles is just plain horrible!
ok thanks people, So will a gtx 660, i5 3570 and 4gb of ram be good enough for a few years ? i have an xbox just now so when new ones come out i might buy them and sell old one
You want the 7850 or even better the 7950 and cop the free games. The nvidia 660 is meh for the price.
If you haven't already, check out the steam webpage/client. It's like Xbox live but NO subscription fee
If you want we can spec you a mini-itx rig in the prodigy case if you want something small. You'll see videos on youtube where people use XBMC as a front end to playback videos and launch steam or other programs......all this can be done from an Xbox pad![]()
