pc out of nowhere running way slower in games?
24 Aug 2015
Turned pc on this morning and tried too games and they are both running ****** compared too last night, deep rock galactic i had locked too 120fps and hots 120fps and both would hardly dip, now I loaded up hots and im getting 80 ish and deep rock 50, what should I be looking at? GPU usuage says 100% cpu temps fine, used ddu and reinstalled drivers, dno what else too check,
pc - 10700k
3080
32gb ram
m.2 + ssd
pc - 10700k
3080
32gb ram
m.2 + ssd
Drivers drivers drivers. If you've already tried nvidias latest, try them again.
Then try older ones you had before.
Also try updating mobo drivers and check things on cpu z (eg ram hasn't defaulted to like 1333mhz stock or something silly
its the drivers for sure, I unistalled old installed new and everything was fine (first time changed nothing) started pc again this morning and once again games getting crap performance, I noticed that nvidia settings isnt saving max framerate either, I have used ddu 4 times now, now idea wtf is going on
Have a look in your windows update history. Is windows replacing with a generic driver? Auto update sometimes screws up
Also if you have any kind of auto update from nvidia id turn that off too. I never trust auto updates for this reason you're having
