PC-P50 Owners
11 Oct 2004
Just a couple questions for anyone who might own the case, as I'm thinking about picking one up as my new case.
Firstly, wondering if anyone knows if the Asus Rampage II Extreme Intel X58 motherboard will fit in the case. As I've read it's slightly larger than standard boards.
Secondly, how much room is there for graphics cards (i.e. length). Again I've read so could be wrong, that current top end ATI's wont fit, will the Nvidias?
Cheers to anyone that can answer. :)
This link below may help somewhat with the second question... he actually holds a tape measure up so you can see the actual clearance
The first question is a little tougher and I'm afraid I can't answer it truthfully
Hope this helps anyway
Just found this link as well
Gives max length of vid card as 285 mm and shows position of standard ATX card when fitted, so you'll get a better idea of the extra space still available
ATB
Cheers for the Raptor, about all I could find myself.
Was just hoping someone who actually had one themselves would give some input, or perhaps one of the OcUK lads could answer for me. :)
IT IS EXACTLY THE SAME FROM WHAT I KNOW AS THE LANCOOL K62 BUT THE LANCOOL IS MADE OF STEEL INSTEAD OF ALY SO YOU CAN FIND OUT MORE FROM THE WEBSITE ABOUT ONE OF THOSE
Just incase someone else is wondering the same and happens accross this thread:
PC-P50 won't fit the Rampage II.
Finally sent a webnote and asked the lads at overclockers themselves and Gary confirmed it.
It will take a graphics card up to 10.5" so the likes of a 5970 will not fit. It's a OK case but the Lancool K62 is much better value for money.
