Hi, i have the PC-P50R case and i would like to add a fan in the 5" drive bay. What can I do?
Are there any angle brackets you can buy that will mount to that area?
It cant be mounted directly against the front of the case because there are removable slots.
My top gtx 460 seems to hit 80c so I would like to know the best option for cooling it down.
Also, are there any programs that will let you change your chassis fan speeds. I have tryed speedfan but it only detects the cpu fan.
Any help would be appreciated.
