- 11 Aug 2007
Hi,
I've only noticed this issue start occurring today and can't recall it happening before now (though I've only had this system up and running for about two weeks, it's still pretty much brand new) but whenever I put the PC into sleep mode it will stay 'asleep' for about ten minutes or so but then it will start up again of it's own accord.
I looked up what devices were allowed to power the PC up again from sleep mode in command prompt and the only things listed were the keyboard, mouse and ethernet ports and so I disabled both the mouse and ethernet ports from allowing the system to power back up, the only thing enabled now is the keyboard. I also checked command prompt for the system wake information, basically telling me what woke the system up the last time it happened but it is showing nothing there (none of the devices I mentioned).
This is still happening, even after disabling the listed devices from powering the system up, and I haven't installed any new software or have anything running that could cause this so I'm at a bit of a loss as to what is causing this problem.
Any suggestions?
Any suggestions?
