PC powers on, but nothing shows on screen. 2080Ti GFX card has red glowing lights...
30 Dec 2020
Has anyone seen this issue before:
Custom build via Overclockers. I haven't changed anything on it for quite a while (only added SSD), purely using it for some light gaming.
It worked fine yesterday. Today it's not showing anything on the display when powering on, however it does seem to run the fans harder.
GFX card is glowing red, though to be honest my PC tower faces away from me so I never see what colour / if it glows at all.
Does anyone have any suggestions to resolve this? thank you
PC Specs listed below.
  • (1x) AMD Ryzen 9 3950X Sixteen Core 4.7GHz (Socket AM4) Processor - Retail
  • (1x) Asus GeForce RTX 2080 Ti ROG Strix OC 11264MB GDDR6 PCI-Express Graphics Card
  • (1x) Team Group Night Hawk RGB 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - RGB Black (TF1D
  • (1x) Samsung 970 EVO Plus 500GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive
  • (1x) Asus ROG Crosshair VIII Hero (AMD AM4) DDR4 X570 Chipset ATX Motherboard
  • (1x) Corsair Hydro Series H100i Platinum SE Addressable RGB Performance Liquid CPU Cooler - 240mm (CW-906
  • (1x) Kolink Continuum 1200W 80 Plus Platinum Modular Power Supply
  • (1x) Corsair Crystal 680X RGB High Airflow ATX Case - White Tempered Glass (CC-9011169-WW)
Does it seem like it's booting normally? Hard to describe but what I mean is, do you think it's starting up as usual but perhaps the display is just not activating? Hdd case lights and fan rhythms can be used to tell.
Also, when you say fans are driven faster. Is that from the get go? Or do you think windows is loading behind the scenes?
I'd turn everything off at the plug, pull the plug, press and hold the power button and then wait 10 minutes or so.
Have you moved it recently? If you have, I'd make sure everything is firmly seated, by just giving them a little push. You could also try the PC in a different orientation (e.g. horizontal), which can also help if the graphics card is sagging.
If it's easy to get at and you have one spare, then a new battery might not hurt too.
I would start by clearing the CMOS. There is a button at the motherboard IO on your motherboard. See if that helps.
There is also a post screen on your motherboard, located above the RAM sticks that displays error codes that can help with figuring out what is causing the issue. The error codes should be in the manual.
Sooo... I managed to borrow a 1080ti gfx card to test with. Popped the card in correctly. Powered on and... POP, the ******* PSU died. So maybe this is the reason for my power on issues yesterday (not enough working juice to power up properly).
However this is the 2nd Kolink PSU that's done this to me in this PC (previous one Overclockers replaced). Last time I'm buying Kolink garbage
I'll buy a different one asap and hopefully the GFX card(s) is actually ok :rolleyes:
Get something gold rated with a 10 year warranty.
Good call! On a friends recommendation I went for an EVGA, and picked this one:
EVGA SuperNOVA 1300 GT, 80 Plus Gold 1300W, Fully Modular, Eco Mode with FDB Fan, 10 Year Warranty, Includes Power ON Self Tester, Compact 180mm Size, Power Supply 220-GT-1300-X3 (UK)​
Kolink PSU. Say no more. There’s a reason they are cheap. However, don’t write off the brand as a whole: their Citadel Mesh case is a cracker. That replacement EVGA PSU is complete overkill but will serve you well if you upgrade to a Threadripper or Xeon W.
You really don't need that much power id suggest save your self some money with something like this
