Hi there,
Been given a PC to fix and just wanted to run it by you guys. Story goes is that the power switched off whilst the machine was being used and now won't boot up.
Upon further inspection the RAM LED on the motherboard (GA-8S661FXM) is flashing and only fans are spinning round. No HDD spinning or CD drive open. Also when i hold the on/off switch the machine does not switch off.
I have replaced the PSU and no improvment.
Tested the HDD in another machine and spins up and is detected in BIOS - so that is ok.
Initial thoughts are that the motherboard has gone. I can test all the cards and RAM in another machine.
So, is my theory right suggesting that the motherboard is dead and everthing is ok?
And is there any way of testing a P4 chip as I do not have any P4 motherboards available or will it be ok?
Thanks.
Thanks.
