PC Problem - No signal to monitors
3 Nov 2019
Last night I switched my PC off as usual. When i went to turn on it on after work the next day, the PC turned on but restarted after around 10 seconds. And since then, the PC has been turning on but there is no signal on my monitors.
I have tried using a different monitor, a different HDMI cable and power cycling etc.
Any help would be much appreciated!
Thanks in advance.
First off unplug from the GPU and then reconnect.
If that fails, remove tha gpu and use onboard graphic. That'll determine if it's the cable or gpu.
You could also try a different pcie slot and see what the results are.
Unplugging and reconnecting did not work.
Onboard graphics do not work.
Different PCIE slot did not work :(
The monitors react to a cable when the PC is turned on as the monitors also turn on. However, it still displays the no signal message.
What about a TV?
No luck :(
Again, the TV recognises there is a cable connected in the HDMI slot as the source is highlighted as if it should be connected and working.
Seasonic 650W PSU
Intel Core i5-7600K 3.80GHz CPU
Gigabyte GeForce GTX 1060 Windforce OC 6144MB GDDR5 GPU
Samsung 500GB 860 SSD
Seagate Barracuda 1TB 7200RPM SATA 64MB HDD
Alpenfohn Brocken 3 CPU Cooler
Gigabyte GA-Z270P-D3 Intel Z270 DDR4 Motherboard
Team Group Vulcan 2 x 8GB DDR4 RAM
Asus Xonar DGX 5.1 Sound Card
