- 25 Mar 2006
- Thornbury
hi there
yesterday my pc went on the blink, all i was doing at the time was copying files from one drive to another.
my monitor went blank and i could not switch the pc off using the front power button, i had to switch off at the back, i switched it on a few times and still nothing, there was a slight smell as if something had overheat but it was only slight.
after half an hour i tried again and to my surprise it started ok and i had a picture on my monitor however my usb mouse and keyboard were not working and my usb wireless network adapter was not working. my usb ports are onboard 4 rear and 2 front.
im using an old mouse and keyboard just now and connected to my modem with a network cable but my usb ports are not working. I checked the bios settings and the usb controllers are still enabled and usb mouse and keyboard are still enabled. in device manager all the usb controllers look ok ie no conflicts.
can anyone help me here to find out what is wrong and possibly fix this or does it sound as if my motherboard has a fault with cant be fixed.
