Hi all.
My brother has the following PC...
Athlon XP 2600+
2x 256MB DDR ram
Asus motherboard
Radeon 9700 128mb
80 gig HDD IDE
DVDRW
CDRW
1.44 floppy
56k internal modem
Generic 400W PSU was powering this for some good 3 years.
He has had it for about 3 + years & a recently the PSU died.
He was playing a game on it & then he heard a noise & the PC stopped.
The PSU fan wasnt spinning & we assumed PSU died & needed to be replaced.
So he purchased a ThermalTake TR2 430W PSU.
Put that in & the pc started fine: used internet that day & all was ok.
Next day he says he was on the net for 2 hours without a problem, then was playing Shadowgrounds game for another 3 hours & then (whilst playing) he heard a bang & saw a flash (case is on desk) & the pc stopped.
The PSU was replaced under warranty, & the new TR2 430W PSU was installed. This was tested (this time the CDRW & floppy were left disconnected) & all worked ok for an hour or so.
So obviously mobo, CPU, graphics card etc were fine.
Again the next day my brother went to turn the pc on & he heard a bang & then smelt burning? - the pc didnt even start up this time.
He called me over, to check things out.
There was no evidence of a short on any of the 3x PSU's btw.
The mobo was still sitting ok on offsets (not shorting) & no bulging caps or anything i can tell. No cables were touching case.
He was using a surge protector on the power socket, & that didnt trigger so no power overload or anything like that, i shouldnt think.
Whilst the PSU isnt that great it should run that system shouldnt it & the chances of 2 faulty PSU's are slim.
I tend to think something else in the pc is causing the PSU to die, as each time PSU is repalced the system works without a hitch for a period of time. Anyone have any ideas?
TIA.
Athlon XP 2600+
2x 256MB DDR ram
Asus motherboard
Radeon 9700 128mb
80 gig HDD IDE
DVDRW
CDRW
1.44 floppy
56k internal modem
TIA.
