Hi all,
My sister bought an Advent T9304 computer 1 year ago. However, she's been experiencing a few problems which include:
- Monitor remains in sleep mode when computer is switched on.
- When the monitor does decide to switch on after leaving and rebooting the computer a few times, it tends to freeze, most frequently when playing games.
The computer has been sent to some computer shop who have concluded that the motherboard (MSI 7091) is causing the problem. However, I'm not totally convinced and would like to see if there is anything you guys could suggest I do to ensure there isn't something else causing the problem. I obviously don't want to start buying new gear unless it's necessary.
The spec of this system can be found at:
Advent T9304 Specs
According to the computer shop, the graphics card has been tested and is ok, but the power supply is only 350w so I was wondering, could this cause the problem? Or is there anything else that might contribute/cause this issue?
Thanks for any help!
Advent T9304 Specs
