pc problems
7 Sep 2009
London
Hi,
I bought a titan goliath about 3 months back. working completely fine. came back home today and now when turning it on its shuts down then back on then shuts down and continues todo this until I turn it off at the back.
help?
or just like slight dodgy or something, best way to check is diconnect it, than use on board power button (on the mobo) if it has one ?
Ok, might be better posting a note in the customer section below.
I think opening up the case to reset the CMOS should hopefully not make the warranty void.
This will reset the BIOS & loose the overclock.
personaly I would be tempted to ask OCuk themselfs of the problem, before touching it, I m not sure how flexable thier warrnties are
its a gigabyte ga-ex58-ud3r intel x58 pci-express ddr3 MB, how does one do a cmos reset? it doesn't even show anything on the screen it shuts down before anything shows up.
There are 2 pins which need to be shorted on the board, or remove the cmos battery fot 10 mins (the cmos reset pins tend to be near the battery,the manual will show this)
i appreciate your help. I dont have the anti-stat gloves etc and correct equipment todo this properly. tbh this seems above me. ill post on the customer services. might have to let the pros sort it out. i was hoping for a quick fix but this problem seems above that.
thanks everyone
Make sure that it is not plugged in/turned on at the back switch if you need to short the pins as you could do some serious damage. Not sure about your board in particular but mine came with a cap that you put on two pins instead of shorting it with a screwdriver!
