Pc problems.
17 Sep 2014
Didn't know where to post this, sorry if its in the wrong section.
Looking for some help, basically my new pc was built today, and everything seemed ok until i got it home, and got a blue screen, updated bios as i heard that it was unstable without it, thought that would be the end of it, then all of a sudden, my pc freezes and i have to force restart, i am really stumped as this build has set me back nearly 2k, and is not nice, i'm pretty certain it was built well, as the guy i got to do it knows his stuff, but hes away atm so i can't ask him and he is usually in london with his work.
Current build
ASUS x99-S MOBO
Intel i7-5820k cpu @ 3.30GHz
16GB dominator RAM
AMD Radeon R9 200 Series
Samsung SSD
Hydro corsair H80i watercooler
Event logs are currently full of DistributedCOM / Kernel-Eventtracing / DNS client events.
https://www.mediafire.com/?6o6oblb6q2wbto1 is the bluescreen dump.
Temps are fine i've been keeping an eye on them, nothing overclocked, did a furmark stress test for 20mins, no problem, any help would be greatly appreciated as this is very concerning.
UPDATE! PC seems to be completely freezing now every half hour, i mean stopping completely, doesn't shut down or BSOD, keyboard and mouse lights go off, and can't do anything except hard reset!
I think this is going to be a case of trial and error.
Couple of things to try / check;
If you can check the RAM voltage in the BIOS as it might be the case this needs increasing a notch and run me test, link below (this runs separate from Windows)
http://www.memtest.org/#downiso
Was this a fresh install of Windows?
What is the make / model of the PSU?
Run Prime 95 to test the cpu at full load, Furmark tends to do the GPU.
Hi, RAM setting are as such
2133MHz - Vol-chab 1206ishV (up and down a few)
Vol ched same
CPU is 1.040 V AUTO
PSU is a Seasonic SS-1250XM X-Series 1250W Modular Power Supply (PSU) 80+ GOLD
It was a fresh install, i have since re-installed windows, only problem i have ran into is when i was booting and pc got stuck on windows logo and had to restart, so am pretty sure the problem is still here, thank you.
And event viewer i seem to be getting a **** tone of error messages "kernel-processor-power" event ID 35 (Performance power management features on processor 7 in group 0 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.)
