pc probs.
22 Jan 2007
rhyl
hi all, a friend of mine has a prob with his pc which started a couple of days ago.
it only happens when he's playing games(cod2, 4 and world at war beta) after about 15mins his screen goes black with the message "no video signal being recieved" his pc is still running but he has to press the reset button because it just stays like it, then he gets the windows didn't shut down properly screen on restart.
his spec is amd fx70 chip, 4gig of crucial ram, zotac 8800gt's in sli, and an ocz 750w psu.
after the problem happens he has felt the back of his psu and its quite a lot warmer than usual even though the fan is working fine, all other fans on his case, cpu and cards are also working fine. he has also tried different gfx drivers.
we are really stumped with this, anyone got any ideas.
Try running with only one card installed, if it happens again try the other card, just to rule out possible faulty card.
If it does run fine with either card can your friend borrow / test another psu.
