PC - Questions.
23 Apr 2014
Hello,
I have a few question regards my PC and monitors which I'd like to know before I go ahead and purchase.
Pictures are below of the build, they are bad quality since taken on iPhone and are a large size which don''t do them justice but you can just about see what I'm talking about on them.
1) I am currently using the BtiFenix Ronin case. It came with two included, one rear and one front. I'm thinking about possibly adding two upper and the second front. How would the Recon fan controller work with these, do I connect one to the MB and then chain the others to the controller?
Continuing from the fans, there is a little dust building up on top of the HD rack and on the mesh panel at the bottom. Would it be better to just add a fan next to the PSU on top of the mesh panel where the dust filter is below?
You can just about see the dust, where it's a little lighter than the case.
2) The picture below shows the room beneath my GPU, but if I wanted to add another 290 later on is there enough room to do so and would it be a bad idea to do so since they are already quite large?
Had to edit the contrast a little since the LEDS were really bright on the photos.
3) I currently use the 27" AOC Q2770PQU and have been thinking about dual monitoring. Since this is my first PC meaning I have never dual monitored before, is it worth it? and would getting another Q2770PQU be the best for aesthetics or would two 27" be too large?
My GPU has one HDMI output which I use to connect to my current monitor, would I have to use a HDMI cable from the MB to the second monitor or would it be better to use two DVI's coming from the GPU?
Thanks.:)
If anyone has any advice on the dual monitors it would be great, so I could possibly purchase another AOC whilst it's still on sale.
