It's happened 3 times now, not sure what is going on.
Basically my PC shuts off completely, the lights on the mobo stay lit, hitting the power button turns it back on, sometimes need to turn it off at the back for a couple of seconds and then it turns back on again. No changes to hardware recently at all, temperatures are fine, happened twice while playing Fallout 4, and once when using Visual Studio.
I've just used an air duster to remove any dust from the GPU and mobo, and I've also changed where it's plugged so it's now in a different wall socket. If these 2 don't work then what's the likely cause? Faulty PSU?
