Was hoping someone could offer some advice on my problem. My spec is:
Gigabyte dq6 motherboard
e6300 with a scythe ninja plus
7800gtx gfx card
2 x 1gb g.skill ram
pioneer dvr109
4 x 300gb sata hdds
black gold pci tv card
Hyper type r 580w PSU
All running at stock - no overclocking
The PC has never been stable since I put it together, BSODing normally when I watch a film or listen to some music, but rebooting too quickly for me to see the error message. The Last couple of days though, it seems to be just shutting off in Windows and then booting up again, as if someone has pulled the power out. Occasionally when it powers back up all the fans spin up to full speed and nothing happens.
I've tried different ram, it made no difference. Disabled onboard audio (for the original bsod problem) but still made no difference. I've put Vista on another partition but that has the same symptoms so i'm not sure what to look at next as I don't have any other bits I can swap out to test. The CPU seems to idle at 44 and load at 51ish (in speedfan) so I can't believe it would shut off at those temps? I'm slowly going crazy trying to work this out!!
7800gtx gfx card
2 x 1gb g.skill ram
pioneer dvr109
4 x 300gb sata hdds
