- 25 Dec 2008
I have recently upgraded the processor and graphics card in my PC (which also neccessitated a change in case) and it's now developed an issue. Under heavy load the PC will trip out and re-boot. The only things which have changed are the processor and graphics card (full spec listed below). I initially thought cooling might be the issue, but cheking the BIOS after a reboot showed the processor and system temps running at around 40 degrees. I'm inclined to think it's a graphics card issue.
Grand Theft Auto IV is a good example. With the graphics settings at a high, but perfectly playable, level the PC will reboot after 5 minutes or so. Turn these settings down a few notches and its fine. 3DMark 06 trips it out in pretty much the same place (after it has gone through the CPU tests fine).
Current set up:
Intel Q6600 processor
Gigabyte GA-965P-DS3 motherboard
4GB Corsair XMS RAM
BFG Nvidia GTX 260 OCX graphics card
Onboard sound
750w PSU
Coolermaster HAF 932 case
Windows XP Pro SP3
All advice welcomed!
Current set up:
4GB Corsair XMS RAM
Onboard sound
750w PSU
Windows XP Pro SP3
