PC Recommendation - £900
23 Apr 2014
EDIT - Updates below.
Apologies for the second thread, however I've decided to up the budget a little.
PC will be used purely for gaming, mostly steam games such as Day-Z, Rust, CSGO as well as a few upcoming games and hopefully will be able to play the majority of these on good if not best graphics.
It will be kept and upgraded for years to come, meaning a suitable case to allow this is preferred.
Budget is £900.
Thanks.
mini itx build?
YOUR BASKET
1 x Asus Radeon R9 280X DirectCUII TOP 3072MB GDDR5 PCI-Express Graphics Card £239.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £169.99
1 x Gigabyte Z87N-WIFI Intel Z87 (Socket 1150) DDR3 Mini ITX Motherboard £99.95
1 x BenQ GL2250 21.5" Widescreen LED Monitor - Black £89.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £67.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £55.99
1 x Silverstone Strider Essential Bronze - 600W (SST-ST60F-ESB) £44.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x Cooler Master Elite 120 Advanced Mini-ITX Case - Black £39.95
1 x Raijintek Zelos Low Profile CPU Cooler £15.95
1 x LiteOn IHAS124-14 24x DVD±RW SATA ReWriter (Black) - OEM £14.99
Total : £898.76 (includes shipping : £12.50).
had to skimp a bit on the monitor (22 inch) to get it into budget though
alternatively, could get this instead:
YOUR BASKET
1 x Sapphire Radeon R9 280 Dual-X 3072MB GDDR5 PCI-Express Graphics Card £199.99
1 x AOC E2470SWHE 23.6" Widescreen LED Multimedia Monitor - Black £119.99
1 x Cooler Master Elite 130 RC-130-KKN1 Mini ITX Case - Black £45.95
Total : £894.77 (includes shipping : £12.50).
dropped the gpu from a 280x to a 280 (non-x)
the difference in performance is around 5-7%
in exchange, you'd get a bigger screen (24 inch) and a slightly better case (still mini itx though)
Thanks for all the inputs. I have looked at each and come up with this spec. I have also decided to purchase the monitor outside of OC.
Any other inputs you have are also appreciated, or any tweaks to my spec below.
I have added both a wireless PCI and a USB since I do not know which to go for and which would be better for me to use. It would be great if someone could direct me towards the better choice.
Do you think this will be suitable for what I mentioned in the OP?
Thanks.
YOUR BASKET
1 x Gigabyte Z87-HD3 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £82.99
1 x BitFenix Ronin Tower Case - Black £69.95
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £55.99
1 x Raijintek Themis Direct Contact CPU Cooler £19.99
1 x TP-Link 300Mbps Wireless N PCI Express Adapter (TL-WN881ND) £16.99
1 x TP-Link 300Mbps Wireless-N USB Adapter (TL-WN821N) £12.98
Total : £861.44 (includes shipping : £8.00).
That's a nice spec :)
As for the wireless question that is up to you, with the USB adapter you can take it with you and use it anywhere so on another computer as well. PCI will be inside the case so you won't be able to use it with another machine without having to open the case etc. However due to the antennas it probably offers better performance than USB but it probably won't be noticeable
I think i'll purchase both and decide when they arrive and maybe give them both a test.
This is my first PC build so just to makesure, is there anything else I may need? Other than peripherals.
Thanks.
Thanks.
Something like this tends to be useful:
YOUR BASKET
1 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 12V 20cm - Black £4.99
You'll have 3 case fans to power (plus the CPU cooler). That means using a total of four fan headers on the mobo, and ensuing cable clutter. Using an adaptor like the one above allows for powering direct from PSU and helps keep things tidy in front, especially as your case has a window.
YOUR BASKET
Cooling Front: 2 x 120mm (1 included)
- Cooling Rear: 1 x 120mm (included)
- Cooling Top: 2 x 120mm (optional) or 2 x 140mm (optional)
I noticed with the case that there are also some optional fans. If I wanted to purchase the second front, plus the two for the top would I need another adaptor?
There are also Powerline Networking Adapters, which give the best wireless performance (because they're not really wireless...), if you have power sockets handy where your router is and also where your PC will be. They are more expensive than the other two types though.
http://www.overclockers.co.uk/productlist.php?catid=1604&groupid=46&sortby=priceAsc
I did read up on these too and watched a few videos and they do seem a lot better. Is it as simple as an ethernet from PC to first adaptor, and then the same but from the router to the second adaptor?
Thanks.
Ah, hadn't realized only one of the two front fans are included. :)
Thanks for pointing that out Rhoxy.
To power all five from the PSU, you would.
Thanks.
That's basically it. And pair them by clicking their respective buttons, as the guide describes. Nice little vid here showing how easy it is:
http://www.youtube.com/watch?v=9RT1XS7HaUE
I know you are trying to keep costs down but another option instead of adapters is a fan controller
YOUR BASKET
1 x BitFenix Recon Internet-Connected Fan Controller (Black) £23.99
Total : £27.90 (includes shipping : £3.26).
It would only go a little over the budget so it should be okay.
Using a controller, would it make it a lot easier to connect them up if I were to purchase the extra fans? Also, the case comes with 2 120mm included, do you think they will be the same as the ones below?
2 x BitFenix Spectre PRO 140mm Fan - All Black £12.98 (£25.96)
1 x BitFenix Spectre Plain BLACK 120mm Fan £5.99
I'm thinking about adding some blue BitFenix LED's too, since my keyboard is black with blue backlights. Which out of the three sizes (20cm, 30cm, 50cm) do you think would be suitable?
I've been thinking about upgrading a little from the recommended graphics card below.
I have been looking at the ones below.
YOUR BASKET
1 x MSI Radeon R9 290 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £335.99
1 x Sapphire Radeon R9 290 Tri-X 4096MB GDDR5 PCI-Express Graphics Card (11227-03-40G) £329.99
1 x Asus GeForce GTX 670 Mini 2048MB GDDR5 PCI-Express Graphics Card £299.99
Asus Nvidia GeForce 2GB GTX 670 DirectCU II which OC do not sell other than the mini.
Which one do you think is the best out of the ones above, or if anyone has any other recommendations at the same/similar prices that would be great.
Out of the GPUs above, I'd recommend the Sapphire 290 Tri-X or the MSI :)
(if your budget allows, if not the Asus 280X is a nice card, I've just bought the Asus 290 version, very nice cards) :)
Do not waste your money on the 670. If you going to spend circa £300, then go for the 290.
In regards to extra fans, get your system up and running first. If, for some reason you have any heat issues, then look at adding or replacing fans. And if you do decide on installing a couple of more fans, if the mobo does'nt have enough fan headers, then just get a fan splitter. Something like this.
YOUR BASKET
1 x Akasa PWM fan splitter (AK-CBFA04-15) £2.99
Total : £5.96 (includes shipping : £2.48).
