pc remote control
I think the Windows Media Centre remote will allow you to do that, the ATI AIW remote (if you can still get them) allows you to control the mouse and could therefore be used but it is less elegant as a solution since it has unnecessary buttons. I'm sure there are also others but I don't know which would be best of the remainder.
http://www.soundblaster.com/products/product.asp?category=1&subcategory=16&product=14709
Or go the whole hog and dont look back (I cant live without it now) and get :
http://www.soundblaster.com/products/product.asp?category=1&subcategory=16&product=14659
http://melloware.com/products/intelliremote/
Now works with the USB Version also.
If you want to choose you music from 6' away need remote but also want HTPC front end, such as Media Portal. That way you can see what you want to play.
thanks peeps its been great help!
im going for the i/o drive upgrade kit so i can use the optical out and use the volume control too. thanks a lot
