- 4 Jul 2013
Hi all,
this isn't really gaming, this is bare bones.
hoping you can help - you steered me in the right direction last time so i'm trying again.
So, tomorrow i'll be having my first online piano lesson. I also have "in house" lessons but i'm wanting to learn something particular which requires a teacher a bit too far away. Therefore - online it is.
Anyway, I was intending to use the now jobless gaming laptop as the hub but wondered if there's a simpler option. I don't really want to have to set it up everytime I go out there, run charger cable etc even with a USB hub getting things plugged in is going to be a hassle.
Now, we also have an old desktop I could "upgrade" if required to do this job, but perhaps I don't even need to upgrade
anyway,
what is the actual computing power I'd need to:
Run Zoom
Run 2 webcams at the same time - once being overhead, the other being a side angle view.
Run a Node USB mic (or similar USB Mic)
Suppose store some sheet music should I want to use the monitor to view music.
That's about all it needs to do. Basic as anything. Just would mean I could then leave it setup in there permanently and simply turn it one when I'm in a lesson or recording some practising.
don't want to spend more than £100. So there's a challenge for you! I'll see what the old tower we have has in terms of internals and maybe spend a few quid putting some upgrades in there. But other than that i'm really just after a bit of advice in terms of a spec I need - i.e. will it even need a graphics card? minimum RAM requirement? min processor I should aim for etc. Stuff like that, as if spending £100 on the old tower gets the job done better i'll go with that.
anyway,
Run Zoom
