Yes the first bit i wrote, if you go through the relevant options it will ask if you want to reset windows and keep files but not apps, or to just reset windows to fresh with all files deleted.Brilliant,I’ll give this a go.
when I follow those steps will it prompt to keep windows 10,if not how do I reinstall Windows?...as I said totally new to me.
