Hi,
Last week one day the PC restarted itself ungracefully after about 10 minutes of running (nothing intensive, just Netflix) then again after about 10 minutes it happened again and was then fine for the rest of the night.
The other day it happened again a couple of times.
Yesterday it happened about 3 or 4 times, couple of those times it was not anywhere near 10 minutes, it pretty much just booted and then went down again.
What happens?
- Randomly restarts
- Boots up fine itself after the restart without me needing to press the power button
- Leaves this behind in event viewer:
There are no error codes within the event itself to indicate what caused it.
PSU is about 9 years old as are most of the components (apart from AIO cooler and GFX card which is GTX970) - rest of spec is as per signature
Going to run memtest but any other ideas aside from that. Could PSU be on the way out? Would that cause restarts?
Thanks!
What happens?
- Randomly restarts
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Thanks!
