PC Restarting, now nothing
25 Nov 2004
I had a problem a while ago with my mouse which froze on me after an hour or so use. I replaced it and everything was fine.
Last week it started again but also included my keyboard. The PC then started to reboot itself after 15 minutes or so (not always the same length of time).
I starting getting messages on startup (before XP kicks in) that overclocking failed so I went in and switched OK off.
Now the PC starts, making all the right noises..fans, light on MOBO etc, but I get nothing on my screen (although power is there) and my mouse and keyboard have no power.
I have tried a new power unit, but nothing. I doubt there was an overheating issue, I cleaned my Zalman monster of a fan and put on new thermal grease.
Any ideas guys??
Spec (own build)
Asus A8V Deluxe (939)
AMD Athlon 3200+
1.5mb Geil memory
Just checked Asus forums...It seems there's been a couple of posts similar to this over the last couple of weeks (coincidence)
Remove the GFX card, replace GFX card & reset CMOS, Fire it up at default & see where you are.
