After shutting down my PC, it has started booting for about 2 seconds, fans and lights, then effectively restarting over and over until eventually it boots. The main thing I note is that when it DOES boot, that's then the LED codes start popping up on the Gigabyte board - before that there's nothing on the code display at all while it's rebooting constantly.
Unplugged drives and graphics card, still happens. Tried new power supply, still happens.
I'm unable to easily remove the RAM due to the cooler being smack over the top of them, but that's going to be my next hopeful fix - after that I know I'm looking at the system board or CPU. Any thoughts on how best to diagnose which one it is? Both are still under warranty (three months shy of three years old) but as they're obviously with different manufacturers, I've no idea which one to go to!
Tempting to just go for a Kabylake 4.2GHz and grab a new mobo but I have to remind myself that the stuff I have is still very good spec and in warranty... but... urgh spending time without a PC would be murder. At the moment the PC is still at least eventually booting, and if I never shut it down it's fine. But yeah. Any advice is welcome!
EDIT: Should probably note that I hadn't changed anything on the PC around the time this started happening, so likely a faulty item rather than a setup issue. But happy to be proved wrong!
Isn't it safe from the start to finish, provided you don't change hardware?
