Hey there, I just started having a problem with m PC that I hoped someone could help with, the PC started doing a double boot, then triple etc....until sometimes it restarts many many times until it finally posts, after posting the PC performs as normal, all the overclocks work fine etc.
If I need to restart the PC for am update I get the same issue, even if the PC goes into sleep mode the same thing.
The Mobo basically stays dead while is restart looping, no LEDs or anything, the only thing that gets power is the fans. I tried all the usual stuff, disconnected everything except the Ram, PSU and CPU. I reset and reflashed both bioses and tried leaving the battery out for a while.
I gave in the other day suspecting a faulty mobo and bought a replacement which wasn't easy since all the z97 boards seem to sell for way more than they cost new. I had to take a small downgrade to a gaming 5 but it was the only z97 board I could find not going for stupid money. I just finished putting the new board in and it did exactly the same as it does with the other board
Im starting to think now maybe its a problem in the PSU, I don't think it can be the CPU or RAM since the board isn't powering up at all. Would a blown capacitor cause the symptoms im getting? Or is it likely to be something more complex, I don't mind changing the odd capacitor but I haven't got the expertise to be testing the PSU for faults. I do have a multi meter so if anyone knows there way around a PSU is there any tests you could suggest?
Any suggestions would be great, I don't mind having a backup Mobo but I don't wanna end up with a spare PSU too if I can help it.
Cheers.
Cheers.
