Hi Folks,
System has been running fine since built in 2010, it was my 1st build so it does have a special place in my heart
But over the last few months I've been having regular random restarts and 99% of the time whilst gaming, no BSOD or crash dumps. Event viewer doesn't provide anything meaningful, just power-kernal 43 which doesn't give the actual problem.
Have done loads of diagnosis to identify the problem (clean install of OS, swapped out HDD, MEM tests, BIOS reset and updates, core temps are good ran prime95 for 12hrs and didn't exceed 60 degs under load). I think the GPU is the culprit (furmark seems to always trigger a restart).
My question to all you helpful people out there is should I simply replace my GPU? or is it time to invest in a new mobo and CPU as well as the GPU? I have a budget of around £400 max (system spec is listed in sig). Many of the parts I think I'm OK in saying are still OK to be reused?
Many Thanks
Many Thanks
