Hey Guys,
I seem to be having a strange issue, over the last couple of days when ever i restart my PC it reboots twice and prompts me to do a Windows Repair.
I have tried the repair but no issues have been found, if i just select Start Windows normally then it boots up fine. Not had this issue on a normal power on just on a restart. This is annoying to say the least, can anyone offer advice on what this issue could be?
When i hit restart windows closes normally, i then get a black screen and hear the sounds pips from the motherboard then Motherboard manufacturer logo all normal at this point.... it's when the "Loading Windows Logo" appears that the whole process starts again.
I have run the start repair as said no issues found, i have run the windows memory Diagnostic tool no issues found, i have also run SFC/scannow in CMD and again no issues found.
This will only happen on a restart as i said the PC boots fine from the power on button.
Could this be a software issue?, the reason i ask is because i have a back up image of about a week ago that i could restore or do you think it is more Hardware related?
Any advice is welcomed
Specs below.... PC was built in 2011 i have replaced my GPU and added a SSD about a month ago but have had no issues with them and the PC is used daily.
Thanks guys
i5 2500K @ 4.2GHz (had this overclock since 2011 Stable as a rock)
MSI P6G7A GD65 Mobo
Ripjaw 8GB Ram
Samsung 500 GB SSD (Installed about a month ago no issues)
WD 1TB Caviar Black (Back up + Photos HDD)
EVGA GTX 970 SC (Installed about a month ago no issues)
Corsair HX650W PSU
Windows 7 64 Bit Premium
Thanks guys
MSI P6G7A GD65 Mobo
Ripjaw 8GB Ram
Corsair HX650W PSU
