PC Rewire... Ish.
24 Jan 2009
Edinburgh
Well, i decided to remove my TX650w and fit my older Toughpower 750W.
Removing the TX was a Real pain. It was cable tied to the max.
Start Off.
Some rather pointless cable ties ( Thanks OcUk :D )
Heres some dust bunnies - All removed !
This bit annoyed me :(. The Rear fan on the Antec 900 - and here's the wire for it. Why did Ocuk tuck it behind the motherbaord?
Anyway, i decided just to cut the wires but now the Top 120mm fan has stopped too, so i guess they were connected together.
Anyway, My blu ray player went pop when i powered it back up. Don't know why but thats £70 ish down the drain.
Anyway, Thats my sunday over. :D
instead of cutting the wire, why didnt you just unscrew the motherboard? - its abit like closing the barndoor after the horse has buggered off but still...
Can't see how you blew your BluRay drive I'd be gutted if I was you. How long have you had your rig that is a lot of dust I have very little after a year.
Me Neither - I think it was because it was a Molex - SATA power instead of the SATA cord straight from the PSU.
Had the PC for 3-4 months.
Good point actually. I didn't think about that. Surely its still under warrenty..
I may just do that :cool:
I wouldn't say it's through any fault of your own that it blew up. I've had it happen on a few occasions when using both molex connectors and PSU SATA connectors.
Is the Toughpower any better than the Corsair, I dont really follow the PSU world but I thought the Corsair ones were pretty good.
