Hi
I have got a new pc and need a place to put it. I have the requirments of it being no more than 80 in width as if I had any more I would'nt be able to fit the case in. The pc is
426mm (16.77") - Height
645mm (25.39") - Depth
250mm (9.84") - Width
and is around 23 kg
I need at least two shelves as I need a monitor altough if I can find a case for the pc / mat or anything else that fits the bill as There is a carpeted floor whitch may be an issue of jus placing it on the floor and getting a table over the top with a monitor. Any help will be very apprecated.
Many thanks as I have been pulling my hair out on this one haha
Jacob
and is around 23 kg
Jacob
