Hi,
This is the PC I bought a while ago, to primarily use for music production. However, in light of reading about the launch of the 8800gt I am considering using it as my gaming/internet PC (also because I didn't get it spec'd exactly to what I wanted for a DAW).
Q6600
2gb DDR2 667 Ram
320gb SATA HD
ASrock 4 core dual sata2 motherboard
Dual layer DVDrw drive
Would there be any visible problems to me sticking a 8800gt into this and then all systems go
I am a little bit spectical about the mobo but in reality should it all be fine?
Thanks for any replies
Q6600
2gb DDR2 667 Ram
320gb SATA HD
I am a little bit spectical about the mobo but in reality should it all be fine?Thanks for any replies
