I have just built a new pc and when gaming it will just switch off on me, so i have to turn it back on at power button again. Well it does this the power supply will stay on for a min or two before that shuts itself off aswell.
The specs are :-
1000 watt icute power supply
ASUS M4N98TD EVO motherboard
Phenom 1090t at 3700 mhz cool and stable, It was set at this was at 4100 mhz but did not like it for everyday use due to voltage and temp.
8gb Corsair Vegence ram 4x 2gb at rated speeds
and gtx 480 sli
The pc ran fine and till i added the second 480gtx (why not with overclockers prices on them lol) but since then it has developed these problems now i have tried running it with both graphics cards on there own and it run fine, with both in if sli is disabled it runs fine still, but asoon as i turn sli on it will run fine and till the moment the fans start to speed up on the graphics cards then it shut off instantly. I have checked the temps and they all are reportedly ok from what different software telling me.
I have tried running everything i can think of including running all none essential stuff hard drives, dvd drives and fans on another power supply and leaving main bits on 1000 watt one but still had problem, I am thinking it is the power supply not giving enough power to the system once the graphics cards start getting hot and fans kick in, is this the most likely cause of my problems, as i am at a lose to know whats wrong now.
Any help would be great as i am lost as what to try next.
The specs are :-
and gtx 480 sli
