I could say stop knocking your case >.<
Well, you may have a loose cable(s) inside, might be worth checking that they are all connected well and all your HW is seated correctly. but i'm sure you did that so..
I also have a laptop that if you even breathe on it it goes corrupt and goes blank.... how old is the build, if more than 3 years you may just have mobo/chip on its last legs
