Hi, I recently helped my friend upgrade his old PC but now the PC will suddenly shut down. It happens consistently during a cold boot, the PC will simply shut down, no BSOD. In the event viewer it simply shows that the PC lost power kernel error 41.
Here are the parts of his PC:
CPU: Phenom X6 1055T
Motherboard: Gigabyte 970a UD3P -> Replaced an MSI board that died during a bios update
RAM: 2x8GB -> upgraded from 2x4GB sticks.
Video Card: Radeon 6850 -> gave him my old card to replace his 5770.
PSU: Coolmaster 600W Lite
It's not a heat issue since the temps are fine even under load. I am suspicious of the power supply due to the nature of the PC symptoms but any ideas should be helpful. I have also reconnected the power connections, and checked the power supply using a PSU tester and it didn't find any problems.
