PC Spec Check + What CPU Cooler with Antec900?
25 Nov 2007
London
ok so im going to buy the following items
basically, i just wanna check this is ok and im not gonna end up with a "common problem" and be like how did i miss that post? I chose the normal Ip35 instead of pro to save a bit, the Q6600 is certain, and def set on getting 4GB of ram in 2X2GB so if you have suggestions, please :D
lastly, i need a new CPU cooler, and i have the Antec 900 Case, so what cooler fits in properly and also for that mobo.
Do you have a budget in mind?
And if you're getting an aftermarket cooler, might as well save another few pound and get the OEM version of the Q6600.
Rest of the spec is compatible, but I'm no RAM expert - someone else will tell you if you can get better value for money :)
at or under 500 pounds, all that above + CPU cooler + AS5
retail Q6600 = 6 pounds more + better warranty + resale value
but the most important thing is can i fit Tuniq Tower 120-LFB CPU Cooler (yes i want the LED version) in the 900 case ? :)
Well, if you plan on overclocking the CPU, warranty is gone anyway. But yeah, I think I've seen someone with a Tuniq in their 900 in a thread in Case Central. But if it's possible, I'm sure someone with that exact combo will be along shortly and confirm :)
going a bit off topic, but for example Asus/nvidia comes with overclocking software, + they dont give void warrenty warning
btw i wanted to get this http://www.overclockers.co.uk/showproduct.php?prodid=HS-026-ZA&groupid=701&catid=57&subcat=821
it says 10 in stock, but u cant select and it says no ETA?
I'd rather a Tuniq if I were you, but try this if you want a Zalman -> http://www.overclockers.co.uk/showproduct.php?prodid=HS-020-ZA&groupid=701&catid=57&subcat=821
