PC Spec Check
2 Feb 2009
Years ago I used to spec the PC's but now the one asking for a spec check advise.
PC usage likely to just be web browsing, emails etc so nothing spectacular required.
Any advice on the below:
Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £76.99
Intel Pentium G3220 3.0GHz (Haswell) Socket LGA1150 Processor - Retail £49.99
Corsair Vengeance Low Profile 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML4GX3M2A1600C9) £35.99
Antec VP450P 450W 85% Efficient Continuous Power Supply £32.99
Antec VSP5000 Silenced Tower Case - Black £39.95
Crucial BX100 120GB SSD SATA 6Gbps 7mm Solid State Drive (CT120BX100SSD1) £49.99
Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
Thanks in advance,
Also, Windows 7 and 8 users get a free upgrade to Windows 10. So I recommend that you get a cheap second hand copy of either to obtain your free upgrade.
Thanks, forgot to mention its for a work friend.
Thanks for the heads up on the CPU.
Will suggest the OS alternatives :).
What, if anything, is special about Windows 10? I'm guessing not much if MS are kicking it out as a free upgrade.
Will it be similar to Windows 7 in appearance, or is it going down the same path as Windows 8?
Thanks.
Razoo
The start button is coming back! also... other things.
Looks like a pretty big increment. They may be kicking it out as a free OS but I think it will have better than ever fluidity between windows devices, making devices that use windows more appealing.
Windows 10 (X) is worth getting. It's going to look a lot like Windows 8, but with added functionality. They're syncronising all Windows platforms. So Xbox, PC and phone will all basically shared an operating system. Means everything sync perfectly.
Browsers love RAM so get 8 GB, not 4.
And is a full ATX system appropriate, or would an ITX / NUC solution be better?
I thought the start button was hastily brought back in Windows 8.1
I've just Googled Windows 10. Its Start menu looks like a Windows 7/Windows 8 hybrid (i.e. 7 + 8 = 10) :)
I think MS are kicking Windows 10 out for free in an attempt to secure cross-platform dominance.
I learnt some years ago not to adopt a new MS operating system until at least SP1 had been released. ;)
Razoo
