Hi,
I've been researching for what feels like an eternity to find a suitable PC spec for me. I have to admit that the more diggin the more I was able to refine what i am after. But now I seem to have come to a wall in terms of smaller details. Hopefully someone can help with pointers/advice.
Heres the spec:
mo'bo: Asus Maximus Formula or Gigabyte GA-EX38-DQ6
cpu: Q6600 2.4ghz SLACR
gfx: BFG 8800GTS 320mb
ram: OCZ 4GB (2x2GB) PC2-6400C4 800MHz Reaper HPC Enhanced
psu: Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK)
cooler: Arctic Cooling Freezer 7 Pro or Tuniq Tower 120-LFB CPU Cooler
Originally I just wanted to create a budget machine to keep me ticking over til next year when I'll probably go MacBook Pro and Paralells but as I found out - it would cost just as much to try spec up my ageing Athlon 1.2ghz!
The usage: I'm not really a gamer or an overclocker - but i'd like to have those options available to use down the line. Primarily this setup is for design work so photoshop, illustrator, web appz, video, after effects and 3d modelling.
Now I see some people pushing 900w PSUs - am I ok with a 620W? Went with the above as silence is important cos I might be rendering while I sleep.
I don't really get the latency numbers with RAM - but this 6400 ram is supposed to be good...will i notice perfomance diference between brands (i.e . cheaper vs the above)?
I bought the gfx card second hand - hoping that it should cater for my real time navigation through 3d scenes and gaming at 1280x1024 but i know this is the older G80 version board? Will it still cut it?
Motherboard is an issue - i dont want to spend loads of money on features i dont need but equally i want to (dreaded word alert) future proof as much as is possible - hence going with an x38 board for PCIe 2. Which board is better for money?
Cooling - as I'm going to be running stock speeds until i really try and understand how to overclock properly I'm wondering whether I need after market cooling? I do want a cool machine - but it doenst have to be uber low temps. Just so its running sweet. Hence I got two option - my choice is leaning towards cost and performance ratio to each other.
Sorry that this is a long post but I just think it'll be helpful to get info specific to the rig i'm looking at. I patiently waited for the Q6600 20th april drop and am now eager to get this thing sorted.
OS by the way. I guess I need to upgrade to Vista to use the 4gb? is there an XP that I can use instead. I'm only buying 4gb as I can get it now and I also want to use less ram slots to account for future ram buying.
Thanks just for getting through the post! but I'd be even more thankful if you guys can impart some knowledge!
ta
noob101
Heres the spec:
ta
noob101
It's just a money issue that's all!
